[WTS] Alpine PDX-M6 Mono Sub Amplifier
ICE -In Car Entertainment
szmy
Item(s):Alpine PDX-M6 Mono sub amplifier — 600 watts RMS x 1 at 2 ohms
Package includes:
Used
Price: RM SOLD
(Brand New RRP: USD 499.99 Alpine PDX-M6 Mono sub amplifier — 600 watts RMS x 1 at 2 ohms at Crutchfield.com)
Dealing method: COD or postage
Location of seller: KL
Contact method/details: Call/Whatsapp/SMS- 017-3270723
Item(s) conditions: Item is used but in excellent, 100% working condition
Item(s) features:
-mono subwoofer amplifier
-600 watts RMS x 1 at 4 ohms (600 watts RMS x 1 at 2 ohms)
-CEA-2006 compliant
-stackable installation design with front-panel controls
-variable low-pass filter (50-400 Hz, 24 dB/octave)
-switchable subsonic filter (off, 15 Hz, 30 HZ)
-quick-connect speaker and power connectors
-preamp-level inputs and outputs
-Class-D amplifier design
-MOSFET power and output stages
-fuse rating: 20A x 4
-4-gauge amp wiring kit with 80-amp fuse recommended — wiring and hardware not -included with amplifier
-10-1/8"W x 2-1/16"H x 8-5/8"D
Item(s) description:
Alpine packs Class-D amplifier technology into their PDX amplifiers for awesome power from a 2" tall frame. These small-but-mighty amps run so cool they can be stacked together into a single unit — their heatsinks couple together to cool the entire stack. Each amp offers an 8" by 10" footprint, so they'll fit in hatchbacks, trunks, truck cabs, and any vehicles with limited space.
Mono powerhouse
The PDX-M6 mono amplifier supplies 600 watts of sub-cranking power from its amazingly compact body. Beefy internal components and clever engineering keep the power output strong and the noise low for superb fidelity and control. The adjustable low-pass filter tailors the amp's output to your specific system.
Front-mounted controls and pop-out connectors
Front-mounted controls make post-installation adjustments a snap, even when multiple amps are stacked together. Nifty removable speaker and power wire plugs make it easy to install or remove an amp, while ensuring a tight connection and guaranteeing that your speakers work in unison. Gold-plated RCA inputs, outputs, and power connections resist corrosion and signal degradation.
Picture:
Reason for sale: Pencen ICE
