WTA : Performance for waja
nashlovebrown
2,000 RPM
Hi guys,
Below are the simple performance wanna do in my standard waja. but not sure will this give better performance.
1) 8" racing clutch plate or change to 8.5" mivec flywheel + racing clutch? Will there be any different?
2) Change trottle body to mivec or accord one. Bigger size. will this effect the performance when the intake same size and no PNP?
3) Change piston to Mivec piston. should install metal gasket? Will this increase the HP or what?
thats all. any extra advice pls write it down bros. just wanna get extra knowledge in standard mod.
What engine are u using? The trusty old 4G18 or the new Campro? I'm not sure bout the mods that you are planning to do, but for NA upgrade, better start with a good set of exhaust system and replace the cams with performance cams.
