[WTA] MyVI stock Spring
likwei
hi all...
can i potong the stock spring for lower my car?
any suggestion?
i don't want to change sport spring cause my fren say it will be "Bumpy" ...
so i decide to potong the stock spring...
by cutting of the springs..the original springs rate will change..as a result..guess wut..u will get an even hell ride ;)
if u wan lowered..better get a set of realiable lower springs instead ;) good luck man
just to share
Just to share with you bro. I'm using KW sport spring for MyVi, so far no problemo. Comfortability and stability, i think better than stock. My advice to you is, don't cut your spring, go and get some good spring out there. Make sure that you are buying a spring that purposely made for MyVi not Kenari or Kelisa cuz the spring coil is different. By the way as far as i concern there are two type of coil for Kenari sport spring, if you buying a thick one, i think it should be okey. Happy hunting... :smile:
Never cut the springs. If u do, u r asking for trouble. Get a good set of sport springs. There is one guy in the ZTH forum selling GAB sport springs for ur car. Do a search, and u will find it.
How Much the spring cost?
where is the location?
thats local made or imported?
you feel bumpy with that spring?
tQ tQ :)
tQ tQ :)
It cost me Rm550 with installation. I bought it at Jln. Beserah, Kuantan, i think many shops in KL will have this KW spring, maybe with a better price . Actually KW is from Germany, but of course la that MyVI spring is manufactured here under licience i think. So far no bumpy, yet i got 1 year warranty for it. If you got extra money get yourself Eibach spring. My next advice to you bro, don't buy "al-chepo" spring especially from kedai "Abang".It's not worth it. Good luck bro...
i think KW is not that good....i am using for my wira 1.5 & its not much different than my previous cheap APM sport springs.......the feel is plus minus the same........i have used other sports springs in all my previous cars as well....both cheap & expensive ones but i would say that almost all are not comfortable at all. whether progressive springs or not really doesn't matter much.....basically all those sports springs are uprated ones & we have to sacrifice comfortness to a certain extend.......thats it......if want a comfortable ride then dont change the standard springs.
Hi Simon,
Totally agree wif ya. IF u want comfort then stick to ur standard springs. There's always b some compromise one has to take if they want to hav some handling wif their car. Cheerio.
