WTA: FTO!!! please help
5115
Nobody
Helmet Clan
hi,my fren trying to get a FTO & before open a thread, i would like to ask sifu here something about FTO
1)how many version of FTO?engine?gearbox?
2)fuel consumption of each version?
3)maintainance?parts normally failed/broken?
4)availability of used parts?easy to find?
5)how to differentiate between 2.0 V6 & 2.0 V6 mivec beside looking the head cover?
thanks in advance!!!
ok,
FTO, few versions available
GS, GR, GPX, GPX version R
with GPX version R being highest spec.
with different bodykits for the R.
GS = 1800, 4G93
GR & GPX = 2000, 6A12 ( V6 Engine layout)
GS version
ENGINE
Displacement, cc1834
Engine model4G93
Max.power (Net), kw(PS)/rpm125 ps (91.94 kw) / 6000 rpm
Max.torque(Net), N*m(kg*m)/rpm16.5 kg*m (161.81 N*m) / 4500 rpm
Power density8.8
Engine typeSerial 4 cylinder SOHC16 valve
Engine information
Fuel systemECI-MULTI (electrically controlled gasoline injection)
TurbochargerNo
Fuel typeUnleaded regular gasoline
LEV system (Low emission vehicle)No
Compression ratio9.5
Bore, mm81
Stroke, mm89
Final gear ratio
Fuel consumption at 10-15 modes, l/100km7.3
Fuel consumption at 60 km/h, l/100km
GR & GPX versions
Displacement, cc1998
Engine model6A12
Max.power (Net), kw(PS)/rpm200 ps (147.10 kw) / 7500 rpm
Max.torque(Net), N*m(kg*m)/rpm20.4 kg*m (200.06 N*m) / 6000 rpm
Power density5.85
Engine typeV type 6 cylinder DOHC24 valve
Engine informationMIVEC
TurbochargerNo
Fuel typeUnleaded premium gasoline
Compression ratio10
Bore, mm78.4
Stroke, mm69
Final gear ratio
Fuel consumption at 10-15 modes, l/100km8.3
Just like normal car, 5 years ago i use before 1, but owned by my fren.
regular wear and tear parts to car, normal service also..
I useD to see a lot of halfcuts available ( 4~5years ago), becos 6A12 is quite common.. i think perdana can use it..
Bring your mechanic ALONg if you are not sure, or someone who knows a thing or two about cars.
