WTA: AUTOGear Loose.
Ayobjuri
HI all Toyota's Guys,
I'm Using 20bt at and this morning my gear loose. I push From P to D2 same..
The gear cannot engaged.
Is it cable connection problem or the gear box problem?.
Currently the gear at D position..
Before I kena kopak oleh wokshop better i know little bit.
:driver::driver::driver:
loose? can ur gear be engaged tak? if it is SIMPLY loose aka not tightened properly, wobbly, etc then it may be the shifter column bushes need replacing jer
aiiyoo.. itu cable coming out frm bracket.
C clip loose.. hampeh..
but hard to access.leceh to open gearbox console.
