Works High Performance Oil Booster Filter
suhu
9,000 RPM
Works Oil Booster Filter can effectively raise 2-5% horsepower and also increase engine oil pressure by at least 0.4kg/cm. Oil booster filter works on the principle of adding 8 special baffles inside the oil filter core, which increase flow rate of the filtered oil back into the engine by Eddy Conduction. Increased volumetric oil flow and pressure lubricate engine more effective & increase horsepower.
