Works Engineering Pro Adjustable Energizer
autocrazee
Works Pro Energizer (adjustable)
Today's modern cars run a lot of electronic devices and equipments including air-conditioner, audio system, lightings, wipers, alarm, sensors and many others. All these constantly saps power and consume a lot of energy, putting a lot of strain on the battery and alternator. A 12v - 13.8v current may cause problems to the car's ignition system including incomplete combustion and carbon build up. In the long term this reduces compression ratio, less bhp, slower acceleration and increasing fuel combustion.
Works Pro Energizer offers robust, maintenance free protection for electrical loads to prevent erratic operation or equipment damaged caused by power sags or surges.
Features
  • No modification
  • No maintenance
  • Immediate effect
  • Plug & Play
  • Easy setting
  • Fully adjustable (up to 15v)
  • Professional equipment
Benefits
  • Improves ignition, fuel burn, fuel effeciency
  • Increases engine torque across the full rev range, better throttle response
  • Lightens load of the electrical charging system, hence increases the lifespan of the battery and alternator
  • Lowers exhaust emission with cleaner fuel combustion
  • Reduces electrical 'noise' and improves operation of othe sensitive miscellaneous electrical devices (audio system, etc.)
  • More precise operation of vehicles electronic control devices (operation of ECU, sensors, electrical power steering, etc.)
Buy Online at http://www.12v.com.my/Works-Engineering-Pro-Adjustable-Energizer/q?pid=375&doit=order
Alternatively, you can email me at [email protected]
or call me at +60.12.691.3061
Thanks!
