Works Engineering Grounding Cable
PandaMotorSport
1,500 RPM
Description:
The Works 24K Super Grounding System utilizes a 24 karat gold plated distribution block and multiple grounding points for improved idle and drivability. Additional grounding points equalize resistance and voltage between various ground points on the car resulting in a more stable electrical system. This will yield better engine response and horsepower by allowing the electrical accessories to work more in tuned with each other offering a more accurate reading. Each cable is an 8 gauge spiral twined wiring wrapped with signature the Transparent Silicon Were protected and add color to the Circle Earth System.
For more info pls contact Panda Motorsport at:
Office: 603-56117172
HP: 019-2931222
Email: [email protected]
Our Address:
1st Floor, No.30, Jalan PJS 11/14,
Bandar Sunway 46150
Selangor
https://www.zerotohundred.com/forums/attachments/478315.vB
https://www.zerotohundred.com/forums/attachments/478316.vB
https://www.zerotohundred.com/forums/attachments/478317.vB
