Wiring Problem
p.g
All toyota sifus ....
My car having some sort of wiring problem (i think) ... my front "small light", dashboard light and rear light is still ON even the light switch is off ...
Now i have to "cabut" the battery cable to switch them all .... :(
last week already fix it but last only for 1 day only .. now problem start again ..
worst case i think want to do the whole rewiring again .. last time "kedai potong" wiring is suck ... any recommendation on good workshop for wiring ... if do rewiring again how much is cost ??? anyway i'm using 4EFTE engine on SEG ..
Paging cekelat starlet sifu .... any recommendation for good Starlet workshop ..
Tired off "cabut" battery cable everytime when parking :(
paging all toyota sifu ...
please help on this matter ... really tired la asyik nak cabut battery cable :(
paging sifu cekelat starlet king ... can help recommend any workshop for starlet
may be water get into ur car?
last time my fren's headlight on by itself... due to the water goes into the dashboard. the fellow who tint his glass, used too much water.
:lol:
hmmm.....4EFTE in SEG, that's what come into my mind before this. Actually I'm very interest to know, how's the installation ?? many modification need? how about the dashboard you using?? using back the starlet one or SEG ?? intercooler still maintan original top mounting ?? can post a pic of your car ?? wish to have a look of it :rolleyes:
check ur fuses...
check ur grounding wire...mainly on the main fuse box in the engine bay near to the front lamp...
check any lamp wiring touch any other source(+ve) wire...
chinozie,
thanks for da adviced .... i will check it ...
Raymond,
the installation is "teruk" lor ... wiring all mess up ... dat "kedai potong" really do a "cincai" job install my engine ... i think i need to redo back all the wiring .... i'm using back the SEG dashboard with Starlet meter .... engine still standard & using top mounted i/c ... save money now to change front i/c :rolleyes: .. sorry la bro don't have digicam ... hopefully someday can join all the sifu here for TTT ...
check your desh light relay, and test ur lamp wiring see any continuty or not.. sound like a relay is energized all the time and cause the light on.
must solve it asap, energized relay will goes hoter hoter. worry it melt and cause fire.
fues wont blow by relay faulty. only short curcuit will cause fues blow.
i ever had my radiator fan relay fault and energized, the relay melt. thank god the melt wire touch on the igniton + ground and cause the fues blow off to cut the power from the main battery fues.
if the main fues dont cut something will burn.
always think of the worse side. dun just see light on and leave it. hehehe
TE27levin,
TQ for da advice ..... where can i check the relay ?? is the relay located at engine bay or dashboard area ?? like chinozie said to check the fuse .... i already check the fuse and is not burn ... even i pullout the fuse the light still ON ... how much is the relay cost ???
Originally posted by p.g@Jan 11 2005, 13:55
TE27levin,
if the fues burn, ur light will not be on anymore.. :lol:
