Wiring Diagram For Gsr 4g93t
The diagram are included inside the manual when you buy the e-manage. It have all the vital info to install the unit. Don't you spend some of your time to understand what's inside the manual (I know you'll not be able to understand Japanese but the diagram are standard electrical circuit).
If you're not sure, have an experience installer to fix it for you. End of story.
well said
what cipan means is that the settings for the 4g63 will work for your engine. and its all in the greddy manual.
good luck.
ANybody have any idea why does the check engine light ignited when installed E-manage on GSR 4G93?
Some say "its like tat, can't be help but no problem wan"
Anybody can shed some light why the check engine light is on and how to solve it?
hi masters! please advise... i bought an Emanage and rewiring it today. Should i Connect what's all in the diagram like Injector Wirings and Ignition Wirings? the unit came with two connectors and two harness. Also is the setting on 1-2-3 potentiometers is (3-8-3)?
