Wira DIGITAL aircond
thx for reply malyadayala...
when u modify do u need those such thg like blower,etc....
if ya then wat it have with a set?
Bro, u can change the air con alone, but you will need the whole
set..eg. blower housing with the sensors & the correct wiring..
Can be done within 400 to 450 bucks..
cheers
thx u guy,i know wat to do now...
by the way any wiring sifu introduse?where the location?
wan nice work and cheap..
cause wanna save money to mod other stuff....thx
air cond digital
sape mau buat aircond digital.. ? itu control panel sama soket lu cari sendiri. lain lain wa cari upah rm250. tapi function angin luar tarak. adjust angin cermin sama kaki tak bleh... lain oki.. semua function ko kena beli aircond digital punya blower... itu mau rm750/ without installation.. tapi i pakai oke jee.. blower ada.. aircond temp digital oki . i pakai kat putra i. oki.. dah 2thn ...
I oso got question ...my mitsu halfcut come wit no digital aircond panel.. can i just buy/change a panel or need also to change such a blower etc..??
can no problem if u don't want to buy complete set...
only cost u rm120-130 for the parts and roughly around rm180 for installation!
hi all... just wondering... could someone tell me what are the full component needed to run a digital aircond (full set) and maybe their function... planning to change, but takut kena con...
ie.: digital panel, termostat, relay, sensor, etc?
thanks for sharing the info and help...
the blower are different la..digital aircond geh bloweh got some motor/actuator/sensor to adjust the way how the air come out, where it come out...normal blower cant use la....normal blower using manual cable to pull and push....
hm... yeah... need to find the right blower for the digital aircond...
actually i already have the:
- digital panel
- relay/coil and (someone told me this item is to control the fan speed)
- sensor/thermo (a simple wire where you connect to the cooling set)
(correct me if i'm wrong with what i had just listed eh)...
i got to know that these are only half set... still can run... but aircond will feel very funny... what i heard is that to fully function, need to get the blower & blower motor (& cooling coil???) + a very messy set of wire... these to enable the air direction (top down) and also outside air intake...
seriously i also don't know how or what to make the set complete... had read a lot of suggestion in zth, but still pening one... mostly people only pasang the 3 items above only... labour charge around KL want RM120 just to fix those 3 items... kopak man like this...
anyway, any expert opinion? these are what i understand about digital aircond...
