Why do I always get this error??
Originally posted by Torment@Oct 7 2004, 19:24
but i cannot recall seeing your name in car modification topics wor? aside from ICE and general talk the whole DIY section, introduction, and here is all your name. you drive a wira do you not? please tell me why for i fail to comprehen the reason.
that's mean i'm interested in anything, but dunno, then ask questions loo....cannot see almost all are questions?? :P
My error msg :
The XML page cannot be displayed
Cannot view XML input using XSL style sheet. Please correct the error and then click the Refresh button, or try again later.
A string literal was expected, but no opening quote character was found. Error processing resource 'http://www.zerotohundre...
Another type msg ....
Warning: mysql_connect(): Too many connections in /home/zeroth/domains/zerotohundred.com/public_html/forums/sources/Drivers/mySQL.php on line 65
Warning: mysql_select_db(): supplied argument is not a valid MySQL-Link resource in /home/zeroth/domains/zerotohundred.com/public_html/forums/sources/Drivers/mySQL.php on line 68
ERROR: Cannot find database zeroth_forum
Warning: mysql_query(): supplied argument is not a valid MySQL-Link resource in /home/zeroth/domains/zerotohundred.com/public_html/forums/sources/Drivers/mySQL.php on line 101
There appears to be an error with the Zerotohundred.com Forums database.
You can try to refresh the page by clicking here, if this does not fix the error, you can contact the board administrator by clicking here
Error Returned
Originally posted by vestax@Oct 26 2004, 05:40
too many connections which cause errors to the db = server over loading ;)
This msg not overload lah ....
some coding crash with IE .....
im talking about this
http://www.zerotohundred.com/forums/uploads/post-16-1098700390.jpg
and i know its overloading , cause im the one who is monitoring the server .
but for the XML page , its has something to do with the forum it self .
yes, this XML error page, i only got last few days....but now no more liao...i haven't delete/clear any hostory/temp files also...
Originally posted by HidSeller+Oct 26 2004, 09:47 -->
QUOTE (HidSeller @ Oct 26 2004, 09:47 )
--QuoteBegin-vestax
@Oct 26 2004, 05:40
some coding crash with IE ..... [/b][/quote]
ok ...
but i toking different thing ....
after i up date my browser, i also having the same problem cant view....have to close 0-100 page.....then reopen again...then can view again.....i am using IE to view 0-100 website. others website my IE doing just fine.
End tag 'font' does not match the start tag 'img'. Error processing resource 'http://www.zerotohundred.com/forums/index.php...
