WHITE smoke
Motor oil starvation will lead to:
1. turbo internals will overheat and snap
2. engine will be effected severely... like crank shaft bearings, lifters and such.....
plus.....
you might wanna consider that the turbine fans are spinning even if you don't boost....
i think u maybe need this:
1.boost meter
2.vacuum meter
the boost meter is for reading the turbo behaviour....standart boost 0.7bar and the vacuum meter is useful to detect the internal engine problem....which is valve seal problem,piston ring problem etc......u can learn reading the vacuum meter by searching the info on the net.....
no worries guys....just diagnosed n FOUND OUT n RESOLVED the prob.....was a small issue due to breather not big enuff.........now NO MORE white smoke....thanks a lot for bros who have contributed :)) !!!
