Where to find check valve??
EGfan
Guys,
Anyone knows where to buy check valve? also known as 1 way valve?? for air..
Also, where can i get copper piping?? around 10mm diameter
There's a type or check valve that you can find in most of the aquarium shop.
But most of them are made out of plastic.
Some specific aquarium shops or pet shops like AquaEast or maybe the 88 Pets Mart might hold some check valves that made out of bronze which is more expensive and ment to be use for the pressurised CO2 tanks setup for planted tank use.
Cheers:tongwink:
Thanks Newgen,
Just wondering what do they use it for?? In case the aquarium shop ppl dunno what i'm talking about...
Welcome bro, don't mention it :D
Normally you can just ask them for Check Valve or One Way Valve
The purpose of it is to ensure that the air-line in the aquarium won't get to siphon water out of the aquarium when the air-pump is of, or the CO2 tank is empty, thus making sure that water won’t flow out from the aquarium in the air-line to the equipments, avoiding damages.
No, it's not manufactured for car as it's for aquarium use.
As i said earlier, there are 2 types, one made of plastic, one made of bronze
So bronze should be able to handle the heat
EGfan said:
Guys,
So may i know...wat r u planning to do wif it??care to share wif us??:_:
