carcrazy_sbs said:
u migt go hobby heaven and check it out...........
FYI...Hobby Haven has transferred to:
26 (1st Floor), Jalan PJS 11/7, 46150 Bandar Sunway, Selangor.
http://i23.photobucket.com/albums/b393/h_a_i_d_i/Hobby%20Haven/NewHobbyHavenMap.jpg
Hobby Haven is providing 2 sets of drift RC which are Yokomo Drift Package
set (RM1,599) & Tamiya Drift Spec set (RM1,099).
Yokomo Drift Package set includes:
1. Yokomo MR-4TC SD CM chassis, bodyshell (with sticker/decal, side mirrors,
wipers, GT-wing, exhaust), drift tires.
2. Sanwa Blazer 2 channel transmitter AM frequency, receiver, servo.
3. Yokomo Pro Stock II 23 turn motor.
4. TP-M8 electronic speed controller (limit 9 turn).
5. IB3800mAh stickpack battery.
6. TP-C2003 battery charger & discharger.
7. Tamiya Polycarbonate paint.
Tamiya Drift Spec set includes:
1. Tamiya TT-01D chassis, Subaru Impreza bodyshell, TEU-101B electronic
speed controller, Sport Tuned 540 motor.
3. IB3800mAh stickpack battery.
4. TP-C2003 battery charger & discharger.
5. Tamiya Polycarbonate paint.
Both package are prepared as Ready-To-Run/Drift. For Yokomo Drift Package
the car kit only cost RM899.00 and for Tamiya Drift Spec car kit only cost
RM649.00. Both kits are 'Electric Powered' which means battery operated.
yanitry said:
Does anyone know where to get those thing in Kuching,quite intrested in driffting
but so far can't afford to buy silvia or 240,r/c consider ok what
If you are really interested Hobby Haven provides delivery using courier service through all over Semenanjung Malaysia including Sabah & Sarawak. Payments are made through Hobby Haven Maybank account.
option1 said:
Guys...
I'm interested too in RC drifting....
but I got one question, can a 4wd gas rc drifting too???
if can, How to setup the car to drifing?????
Pls help...
Yes, 4wd 'Gas Powered' RC can drift. Normally setup for GP RC to drift is to use solid axle differentials instead of gear differentials.
Kendconcerto said:
Im using HPI RS4 kit (Nitro powered)
But sold my novarossi, now using stupid smartech engine.
I wonders after i put PVC pipe as tyre, can my car drift too ? :P
Normally PVS/ABS pipe tires are not recommended for GP RC drifting due to the power distribution from engines compared to EP RC are different. It is best if possible to use RC radial tires and play along with the RC ride height, toe, and camber setting. Best is to make front setup grip and rear less grip.
