Wheel noise
vicebet
Noob need cross check.
Loud noise coming from front right wheel. Sounds like metal friction.. taktaktaktak.. turn and reverse even worse noise.. when press break the noise gone.
Is it wheel bearing, shaft of something else? Thanks..
Too general.
- Could be brake pads metal to metal (meaning needs changing)
- Could be jammed piston
- Could be bearing damage
- Could be caliper brushing against your rim
But it sounds more like a piston problem. Better get that resolved before you get into trouble
Sound more like coming from the brakes. Like pads rubbing on the disc and so on. Better send for check...
have you changed your rims recently? try check maybe there is a nut / stone stuck at your brake disc. my friend cars happen once. If you changed your rims maybe you can try get the rims if the rims got benkok or not.. sorry for the poor english.. ^_^
