What turbo is this?
synchron
I found a turbo with this specs but i dont what type of turbo it is. It looks like a T-66 but the diameter is smaller?
Can anyone tell me?
Thank you
have u try with any car.....
look ok to me..... is it some sort of TO4E family
how much u got it?.... want to sell it?
don't the T siries turbo start with 61mm inducer......but i'm not so familiar with the T-60 siries turbo... from the picture you post the size of the inducer only 57.8mm..... it maybe a 60 trim wheel but i need the size of the exducer to confirm it....
anyway, i'm only interested with the turbine wheel.... it look like the same as stage V wheel.
i'm looking for that kind of turbine wheel to replace mine which is chip a bit at the inducer....
if you want to sell it i'm interested to look at it since i have the turbine housing that made to bolt on stock mitsu manifold for that particular wheel...
Yes! but the housing is a T - series type but it is smaller in the inducer. I dont have the turbo. I have ask a friend of mine to send it in from Thailand. I have to ask my friend about the dimension of exducer.
if it cost less than rm2k it should be a good buy.....
but it would be more good if the compressor housing AR is .60 or .70...
as for the turbine housing ar .58 or .68 with divided would be a good choice for a minimal lag but must be without the internal wastegate outlet...
the turbine housing for that particular wheel is a bit hard to find...
I think market value for this turbo will be more than 2k for new ones. The compressor wheels can be upgraded to 62mm according to them.
