what to mod or change?
ryucky81
hi all,
me got year 04 wira 1.5 sedan. it really lack of pwr,FC oso high. recently oredi change exhaust and mid pipe, can feel the diff,smoother. but hor y first gear cannot drag, when accerate rpm will boots up but speed remain leh!!!
any 1 can give me some tips to mod or wat to change.
he he, not intend to change engine.
thanks and regards
For Proton Wira/Satria, changing the extractor, matching the right diameter piping will give significant power. Except the Siemen ECU has gave limitation to the amount of air - fuel to boost up the power. Cheers... :)
ur car
bro, i can reset ur ecu by leaving power cable on the battery disconnected over night. if u know for sure, just unplug the fuse for ecu. but don hope so much in resetting. if u car had been acting poorly, might get better, but if not, u get NO FEEL. ehehheeh.....try other methods like installing piggy backs. might sound pricey, but better than to be leceh by trying out differrent kinda stuffs according to differrent mechanics or frens.
U can purge the data, but re-programming it is very hard and $$$ matter. So it's better to change/add with a piggy back to re-map the fuel. And u can sell off the piggy and gain back original condition if u intend to sell the car. ;)
Turbo kit tahts all. what bout Siemen ecu. will tat effect the turbo performance.
guess it need piggy back also?
By the way, whats the RSM does?
yeah sure need management still....to tune it..
RSM? remove u speed cut?
0-400 and stuffs?
let u see the kmh?
more about siemen's ecu....
http://zerotohundred.com/newforums/showthread.php?t=23818
MONSTER CHIP
1.5 engine...intake n ekzos is welly done should be ok oledi.....n do something at car handling....
my wira 1.5 fuel injection..put knn filter...ekzos standard...but sports absorbers n recaro seats......
not bad...nice to drive......smooth for street/ daily driving
Modification is according to the power u need... turbo = extreme improvement in speed and feel, air-filter/exhaust/plug = better response. ;)
yea yea...depends on individuals one.....
but if u juz wan more power..juz changed simple simple things should be ok.....
1. open port air filter
2. plug cable n plug
3. extractor
4.ekzos piping front to end
5. rear muffler
6. fully synthetic motor oil (e.g Q8)
7. branded gear oil (e.g Q8)
8. sports suspension kits for bettle handling n smooth cornering
9. use 100/90w instead of 60/55w headlamp bulb for brighter lamp at night
10. Tinted ur car..so tat u wont feel hot when drive under d sun.
juz my suggestion....if u can done all tis simple stuffs.....ur car looks better i think
