what should i use for my 4g67
guest
guys in need some help on choosing which and what kind of standalone that can help me reprogramme my setup...now im using standard evo3..currenty im going to install the 4g67 block for my evo3 engine...anyone can give some opinion of some of this items?
1. emanage- cheaper but dunno good or not
2. Haltech-dunno which version is cheaper and good "sprint 500"?
3. microtech..-?lt8?lt10? expensive
btw i also wanted to know if i can just reprogramme my standard evo3 ecu to save cost...my budget is currenty for this item rm2.5k...
my future setup would be standart td05-16g..only change the block with vr4 piston boosting at 1.0bar....is it ok?cos some friends told me that after changing the blok to 4g67..we need to tune back our engine
thanks guys
thanks guys
2.5K is good to go for emanage.
But for more effective customizing chip for ur any set up, I'd go for rechip. It shall be tuned on dyno as well before mapping is finalized into ur ECU.
Almost everything could be done on a rechip including injection pulse duration, ignition timing, launch control, conversion of MAF into MAP, and the list goes on...
But u have to make sure the ppl who is doing the rechip really know what he is doing.... Else, go for emanage only. Less hassle.
BTW, E3 already come with big TD05 16G.
so e-manage is good enough already guys?how about one day i wanna install high cam for my evo3 engine?the emanage still can be use?
