What clutch is good for altezza????
Syamsul Anuar
From Facebook
i am using toda flywheel...but its not make any changer when i use original altezza clucth...as a new owner of altezza....want opinian from all u guy...
i already use original clucth...can i use trd clucth for more kick....
It is not advisable to use a Toda flywheel with a TRD clutch plate. They might not fit together.
It is better to use a TODA flywheel with a set of TODA clutch and cover plate.
Likewise for the TRD flywheel.
errr what does he mean by more kick??? :confused:
kindly explain. putting in a better racing clutch or better clutch will NOT make your car go faster. only makes ur right foot feels numb n sore on traffic congestions(unless original)
faster way is to put in a 4.7 final drive!!! fuiyo u will get instant acceleration
good luck
good luck
good idea...but how about top speed???
i agree with all of u...maybe use original clucth its better....
of course with such a high final drive, u will definately lose some top speed crusing. but again wat top speed are u talking about? crusing at 180km/h? 200? 220? 240?
stock altezza to reach 180km/h with 4.7 is ok, but probably will stress ur engine n gearbox due to high rpm. 200km also ok...u can try hahahah
so u see, there is NO shortcut, u gain in some area u lose in another area. plus how often u can zoom up to 200 on our normal roads? even highways are packed with cars
unless u put in a 1j/2j then u gain in ALL areas. but its pricey and if the workshop is crappy...ur car is a goner.
good luck
