what can i do for automatic gearbox ???
charles_ko7
my ride is proton WAJA automatic , so i need to overhaul my gearbox now, can i
know got any performance part is fit to it ?
example like : limited slip dirffer { LSD}
or some sport clutch like that,
or any final drive ?
all u can do is... change transmission oil...
or unless u wanna mess with the gear ratios and so on...
LSD is called limited slip differential... as the name goes, it limits the slip between left n right tyre during turning, thus putting down more friction and grip onto the road, thus better acceleration out from the corner.... i'm not sure waja gearbox has any compatible aftermarket LSD or not....
racing clutch??... u can forget about it... auto tranny dont have clutch... it has a torque converter instead....
im using auto also...but come to think again..wanna swap to manual...but they said the performance from changing auto to manual should be not far...more or less the same...dont know if its true or not...bla bla bla....have to wait my auto gearbpx malfunction then will go to manual....my personal opinion...fc for auto and manual just the same...i think auto much better than manual..but have to consider the way u drive lar...still for now...i prefer my gsr to be in auto....pickup?huhu yup...very lame...but after a while...sure the same like manual one...ohh ya Fc when driving on high slopes...hills...heheh....beware!!....auto drinks fuels like beers....ahahah
auto has the highest rate of transmission loss, and it's a proven fact, manual is the best power to ground agent you could afford to have at the moment, unless u wan talk bout F1 technology that'll be different thing altogether, and the gearbox itself will cost u a few skylines.....do remember some special gearbox like dogbox and or WRC gearbox will cost a BIG BOMB too, which is y i said we can't compare, back to apple to apple comparison.....
there's one thing i can tell u is that, if u change auto to manual, not only u'll feel the power but u could prove it under dyno as well.... or a simple way if u have an RSM, clock ur current 0-400meter with auto, then 0-400m again with manual, manual will always win.....
auto transmission has more loss due to the torque converter.
its like a fan blowing another fan that drives a shaft.
but one thing most ppl not aware is GEARBOX RATIO.
the ratio for AT is suited to AT and MT to MT. so thats why
some ppl said after convert from AT to MT for that engine,
it feels the s a m e.....
and for example waja AT vs waja MT if Proton tuned
the ratio properly, both can be same performance..
but AT will be higher FC a bit...
my 2 sen nia.
Instead of changing parts and all, why not install a proper gearbox cooler, use good transmission fluid and rev the gearbox kaokao. Hehe
my 2 sen nia.
lol, set aside gear ratios apart for now, mr. guest is jus asking for performance, or unless mr. guest or our mr. waja bros here wanna completely disassemble the entire gearbox and customize the gear ratios and maybe with a higher final drive like competing in a true 400m drag, we're trying not to confuse them.... ur going back to the topic of designing a gearbox with good gear ratios and yes maybe nextime lotus can fine tune the gear ratios for the next gen waja, maybe mr. waja will like to find a gearbox service factory to overhaul and recustomized the entire gear ratios just to beat a manual which i'm not sure what could be their intention despite a very good effort with the least value for money involved......... however as mentioned for the least transmission loss and for the best performance manual is still unbeatable in dyno figures or 400m or anything or any test that could be measured against performance.... but apple to apple, same parameters, same engine, same mod, both in good healthy condition, stock original auto vs manual gear ratio, no more no less....
MT is the best power transmission. yes no doubt. what im pointing out is that, if u have a AT car, and you changed to MT, does not necessarily become more powerful. thats all my point. sorry if u or others have minsunderstood.
hehe...nice nice...so bro..if i change my auto gsr to manual...what gearbox would be the best for me?beside using the gsr one...how about evo?FC would be high?because some says that at 5th gear..the evo ratio(short) would bring more than 3.5k rpm on 110km..+ some say when auto change to manual...would got many problem..sometimes after step the clutch the car would idel...bla bla bla....is it true?so say jest leave the auto to auto to limit the future problem....is it true?
U can always rebuild it with performance ceramic clutches. I rebuild mine for RM 5k. Now, after full service with 100% fully-synth ATF, virtually no slip n has really good torque on 2nd and 3rd gear. Will dyno car in a few days from now. Previously, I've got 156hp on wheel. Hopefully now will obtain even higher due to less slip.
Plus, u can also opt for a 3rd party tranny controller to enable paddle-shift-like function. However, it is not for all cars.
Migrating to manual is not always an answer for everyone. Even in the US, those muscle cars are auto and most owners opt for rebuilt the tranny to take 500hp to 800hp.
On top of that, a turbo-charged auto car is always fun to drive... just jab the pedal n watch others trying to catch up. Otherwise, those with Caldinas n Airtreks would never mod their cars.
frankly speaking, auto tranny can do alot of magical stuff but can't go far enough if same modifications compared with a manual trans.
for Waja, one famous place you should visit is FTD (full throttle dev), located behind Ah Heng exhaust USJ. they done lots of modifications on AT for WPC members if not mistaken.
but using good ATF oil, ATF cooler and a nice piggy back is a good way to start, equipped with CAI and exhaust setup, you will have a better AT than those Wajas stock standard on the road.
further enhancement would be playing with lighten crank pulley, lighten flywheel, retard camshaft, adjustable lighten cam pulley and port n polish... what i am trying to say is NA Power mods.
for FI (forced induction), i do recommend run it on a MT gb is better.
my 2 cents, i could be wrong, all sifus can correct me. thank you for reading my little opinions.
hehe...nice nice...so bro..if i change my auto gsr to manual...what gearbox would be the best for me?beside using the gsr one...how about evo?FC would be high?because some says that at 5th gear..the evo ratio(short) would bring more than 3.5k rpm on 110km..+ some say when auto change to manual...would got many problem..sometimes after step the clutch the car would idel...bla bla bla....is it true? so say jest leave the auto to auto to limit the future problem....is it true?
well u have a few manual options dude, each option has its own pros n cons:
1) Putra / Satria GTi / or even japanese 4g93 NA 2 wheel Gearbox which are all F5M22 gearbox, i'm using the Japanese halfcut 93 NA gearbox at the moment, no problem at all except that the clutch n flywheel n pressure plate are all 8.5 inch, u can fit a 9 inch but u need to remachine the gearbox housing for some clearance. Drive shaft future replacement is not a problem at all, good for general daily use and good for cruising, pick up is OK but still 'boley tahan' (coz turbo mah) and u can gain very good top speed.
2) Mivec close ratio gearbox, if u use this gearbox, u'll have a superb pickup due to the close and much shorter gear ratios, which means the time it takes from 2k rpm to 6k rpm is shorter, some even come with LSD but i don't have any experience and the good or bad bout the LSD (maybe can check with JinKL for some special LSD upgrade?) however the for highway cruising you'll suffer as ur 110km/h will hit a higher RPM even on the fifth gear....
3) 4 wheel GSR gearbox, it's locked at the rear diff for our Msian converted protons, so u get power transfer to the front wheels only, drive shaft is different, pick up is not bad as well, however i've always hear complaints from actual users that the pickup will be a bit slower in respond due to the locked differential, not too sure bout this....
4) VR4 / Evo Gearbox, no experience on this however will need some custom mount or additional bracket to fit with ur GSR flywheel.....
5) Others??
I'm sure and pretty confident u'll be happy after changing to manual, at least for your GSR, i do reckon auto gearbox is not bad too but will you custom mod the internals to the extent of beating a manual? it's all bout money here, everything can be done with the right amount of money, probably a rebuild of ur auto tranny to withstand high horsepower output will cost u the money u can spend on 3 or even 4 manual gearbox and maybe including customizing its internal gear ratios? and plus not much choice here for stock auto trannies swap, there may be auto trannies that are specifically designed for true performance but i doubt it's available as an option for GSR, period. I'm not saying auto is bad, it's good for daily drive but to extract the best power to ground, MANUAL IS CHEAPER to achieving it..... sorry for some pre-judgement i believe if ur really loaded, u wouldn't have asked this question in this forum?
u mentioned for manual after stepping the clutch the idling is bad?? there's something wrong with the throttle body servo motor, get a toyota FICD and it will fix all the GSR out there, me too using Toyota FICD for air cond idling only, but my main idling is controlled by my standalone map....
actually my GSR fren, the GSR halfcut that i bought is also an AUTO from mitsubishi libero !! but i use back my ol'trustworthy MANUAL GEARBOX Japanese spec NA 4G93 F5M222-RRKE (should be from some old 1.8 galant), i dun have any problems at all until recently after my turbo upgrade with huge increase of torque and horsepower, i've scored 260-270 on engine HP and about 350 Nm Torque until my clutch started slipping recently due to its small 8.5 inch flywheel, clutch n pressure plate, the best is of coz 9 inch, but how much of modifications have u done to your GSR?? if there isn't much then dun worry, even if u mod more than 300 HP one day and ur clutch started slipping, so wat? u still have plenty of options to cure the problem eg. racing clutch, or twin plate clutch.......and the good thing bout manual is, GENERALLY (mark my word but every general rule may have an exception) it's always more reliable than auto tranny in terms of failure probabilities for a monster Horsepower output (sooner or later-LAR)
forgot to add, u mentioned bout fuel saving, then opt for the first option like wat i've posted above, it has good cruising RPM !! n dun get any close ratio gearbox, u'll get a good fuel economy, before i mod my GSR, i'm getting 300 km / RM 50 at this year's (or was it last year? forgot lar) new fuel price, but now after mod, only 200km / RM 50 hehe....
That's because MY drivers don't have experience with auto tranny unlike those in US or AU where they have been modding for decades.
I chose to stick with auto for many reasons. And since very few mechs in MY can give solid answer, I've decided to do some R&D myself. Technically, u can mod an auto to behave like a manual simply for reprogramming the stock TCM (transmission control module) and by beefing up the stock seals, clutches and rings. It is expensive unfortunately.
Auto have many potentials which are untapped otherwise why would Toyota even bothered introducing a 8-speed auto in their latest Lexus? Or why more n more cars are getting beefier auto boxes?
Mitsubishi auto tranny aren't exactly strong as stock (in fact, I broke 2 units of W4A33 in 1 year). Instead of discarding them for RM 100 a piece, I rebuild them and today, almost a year later, it still reliable and strong. Can say money is well spent. Plus, it is cheap to source a spare from chop shops. I recently bought another spare for RM 550 inclusive of 4WD drivetrain for future 4WD conversion (hoping to do the legal way).
Now, it is engine mods time - larger turbo, intercooler pipes, larger intercooler, piggyback ECU and an engine overhaul. Hoping to get the car out in a couple of days for tuning n dyno.
Don't look down on AT yet... one must learn to appreciate all trannies. Different people have different requirements.
yea...my fren caldina n myself airtrek also auto....semi auto......just press acceleration pedal only.......response is good though....:_:
