Ways to make the door feel solid when closed...
KGhee
Hi, currently driving satria-gti, with a non-original driver's door (feels heavier than the original one on the passenger side). Don't have the "thump" feeling when closing it...any good ways on how to fix it or least makes it more bearable?
Thought of the following; change back to ori-sgti door (most exp), soundproof the door?; auto-foam the door?
Appreciate the feedback!
I thought all Satria's doors are the same... From ur statement, seems like the Gti are equipped with the different set of doors... Is it? The non-original door come from what model? Satria or Mirage?
I'm not too sure whether all the satria models have the same door. On the non-ori door, i think its from a Satria (not exactly sure since i bought it 2nd-hand about a year ago).
normally if it sounds more like a garbage can closing, chances are its using 1.3 soundproofing which is minimal for weight reduction purposes. you can opt for some sound dampening material n diy behind the door trim.
SR3 uses 1.3 sound-proofing n wind noise is very obvious..but fast
Yeah, it does sound like garbage can closing...not that you mentioned it. Will consider looking into sound dampening material then. Wonder if the ori gti door has sound a thicker sound dampening material?...Will probably open up and check for myself...
there is a possibilty...did u buy an accident car?coz when u buy secondhand car,u dont really know what had happened to the ride...
Coz last 4 years back,my parents purchase a 2nd hand Perdana V6...the drivers door are like lighter than the co-driver's door...n when close it sound like garbage can...N when driving it,the sound of the wind is more louder than the co-driver's side...
Yup, its not a totally accident free when i bought my ride. Just trying to see what options are there to improve on the "garbage" can sound effect :).
its the same door la..bmw 318i and M3 also using same door...
ok, now back to ur question, most car doors will start to sag as it ages, due to many reasons. ie: how the owner handles his car wt care or not, water sipping in over the years will make ur door panel saggy as its made from foam or fabric, broken clips, pumping stereo, rust..etc etc
since urs is gone, i suggest you find a new door panel, or you can actually DIY it by opening it up and giving it some cleaning, replacing broken clips putting all wires back in place etc, however this is only if ur door panels are not "swollen" due to aging...
if you have big pumping speakers, this will also cause ur door panels inside screws etc to loosen up over time due to heavy vibration. so if you hv powerfull speakers, after you do all the above, insulate the door wt sufficient good quality foam AKA sound proofing.. much cheaper if you DIY it.. sound proofing could cost you a bomb at accesorry shops...
good luck!!:biggrin:
What PocketRocket is true... The soundproofing for every cc is different... I was told by a friend, that the 1.6 door got sponges inside of it... while the 1.3 got none...
wanna have a more solid feel when closing the door, u shud look for bitumen strips. very dense and good for diy-ing. u understand ur car more when u diy.
if u can, try to look for the rubber door lining..bro Sach has a point on its wear n tear.
