water leaking when big rain
audiolizard
my car has remove the top part of the rooft and replace a new 1 cause of the sunrooft,
so the problem now is, when encounter big rain, the water will leak in slowly and i mean very little and slow from the rooft which is not the sunrooft area but the front part of the rooft contact to our windscreen. and what am i thinking is, the car might be welded not good enough? or the rubber is torn out? any1 encounter this problem before? sifus help please.... i appreciate..... thx
I'm suspecting that the drain pipe ( small tubing ) not functioning well thus the water flooded to the front part of your roof and seeps in. Also try checking the rubber of your windscreen if its still in good condition and/ or properly glued.
