wat ecu is this?
lan evo
3,000 RPM
wat ecu is this?spoon n1 spec?
vtec engage at 4200rpm
http://img.photobucket.com/albums/v369/ken_7216/21092007550.jpg
http://img.photobucket.com/albums/v369/ken_7216/21092007552.jpg
looks like a small board p08 or similar in another case.
the case supposedly has two power transistors on the side (the clips for them are there)
but the board looks like a normal single cam vtec board.
I'm amazed the ECU still works because the power transistor next to the connector can get pretty hot and burn itself out.
It is chipped though, but as to what programme.. I'm not sure either.
its a manual single cam vtec ecu p08. the chip is not original aftermarket chip. its a copy chip.
the casing being changed i think..
