Wastegate Explained.
Just for your information, get a bigger midbox and exhaust system before the heat and back pressure damage ur O2 sensors and turbine. 2.5" for a 1.6 will be good...
Oh, my o2 sensor is not plug in btw. Its juz mounted there to plug the hole:biggrin: 2.5"??? Hmmmm.... not too big meh???:hmmmm:
chill guys, dont fight
the only problem with tial is , tial in malaysia are mostly not original
im also running turbosmart , speed2horizon is also running one
i faced problems with the turbosmart bt was solved with help of sdf with lil tweak of spring rates
one more issue in malaysia is choose the wrong size of wastegate n etc
tials are proven same as turbosmart :) we are still far slower than the other cars in US who is running on tials, they run higher boost than nearly all sepang cars
john shepherd 7sec 4g63
http://sphotos.ak.fbcdn.net/photos-ak-sf2p/v288/197/78/19738257875/n19738257875_731187_7600.jpg
evil eagle 8sec 4g6x
http://www.dsmtuners.com/gallery/files/1/0/2/1/2/2007build032_1.jpg
twicks 9sec 4g9x
http://www.dsmtuners.com/gallery/files/2/8/7/2/3/4.jpg
so dont worry guys, its ur choice , i head for turbosmart becos i want to avoid the fake tials
the picture picture look like hehe,but anyway u got the point already..
me too bro..just to avoid the fake tial in the market.I really unable to differantiate the fake and the ori tial.
price wise more a less the same.. so just try out turbosmart and it serves well
twicks 9sec 4g9x
U came in at the right time babe.... I was just looking for the pictures... I thought the STWANGAN's 9 secs 4G63T is impressive enough.. But it isn't...
OUT OF TOPIC A LITTLE, Bro.... I changed my Satria's leg from Japanese T to Local T already... Felt SUPERB.... Haven't been having this kinda feeling for a long time...
Wow.... Unplugging the O2 sensor will make ur car runs Open Loop all the time. No AFR feeback to the ECU. It'll increase the fuel consumption of your engine.
In turbocharged engine, we have before tubine and after turbine exhaust. So, big exhaust is not a problem. 2.5" is just nice for a spirited driving 1.6 supercharged engine... If you wanna prepare for higher boost application, U may opt for 2.8".. But too bad, this size is very RARE in Malaysia....
Not the story anymore... Turbosmart price went up by RM500 for the 45mm within the past few months... Kekeke....
I opted for the TS because of the
color and shape
finishing
smaller community
single piece valve(2nd most important factor)
immitation of TiAL(The most important factor)
Cheers..
@speed2horizon
Yup.... dats y most of the time weekends only I'll drive the car.... The car is not environmental friendly and economical... 1 2 overtake oso exhaust smoke like Pajero diesel hahahahahaa..... Maybe I'll opt for 2.5" piping when my old rusted piping start to give way...
Thanks alot for the info btw... cheers
Hi guys,
thinkin of changing to a tial wastegate as mine is apparently stuck open...
i know it depends on the size...but any idea on the prices??
thanks
yeah i've looked on the net...
there are like one arun 300+...but i dont think these are ori...
then there are ones from 600 - 1200
but was asking arun wat price would be a reasonable amount to pay for one...
i wanted a larger mm size...
38mm is running at RM800 - RM900
44mm is running at RM1200 - RM1400
50/60mm sorry, not too sure. Maybe I can't afford it.
When u wanna install?? I have nothing to do recently and I thought of a nice eat to plunk it into a TD04L. Neat n hasslefree. Wuahaha...
I need two pcs :bawling: . my actuator at the back underneath one. i wonder if the wastegate will be pointing down too. but at the front can easily plunk the 2 inch pipe at the flap hehe
so that's the truth I'm looking for all the while.. really2 need it since i'm installing wastegate 38mm to my L2S.. is it ok? or do i need 35mm?
need advice from all sifu,
my current setup. 1.6 sohc bolt on turbo
td05 14b boosting 1.1bar.planning boosting 1.5bar soon
i just complete custom a water / methanol injection kit to my car,it activate on 0.85 bar.would like to install wastegate b4 tune my car.
1 ) 35 or 38mm suit it?
2 ) after install wastegate can i put back rear muffler to original like inlet & outter 2 inch, will it have back pressure issue?want make it silent .lound when boost.:proud:
Sifus> Did stainless steel piping for my gsr recently however i have changed 2 actuators so far as always overboost and performance also lagging. Foreman is advising me to upgrade to a 38mm wastegate, is that true or actuators are good enuf for this mod...Thanks
Before any of the sifus in here can answer your question correctly, it would be better for you to describe boost related mod before & after the piping change, also whats the diameter of your IC piping.
Stock actuator usually will be sufficient to control boost of a stock turbo on a stock car. If what you experience is boost creep, then you could either port the stock gate or change to aftermarket wastegate. But before you even do all that, check for any leak especially the hose going to your actuator.
