Wanna ask about A31 suspension...
pogo
Hi mike..
NiSMO Guru....
I wanna ask sumthing,
if i use stock abs + spring on A31...
can i put 17" rim with 8" - 9' wide?
Afraid if 'kena' to tha coil...
Thanks inadvance guru's .... :)
A31's rawkkk!!
~take k mike..
hey dude, if ive got RG coilovers on my A31 running 8 inch rims in front and 9 inch on the rears.. tyres are 18"
i run 235/40/18s all around coz any bigger, the sidewall of the tyre rubs against the coilover.. even with these 235s, certain tyres rub, some don't, it depends on the sidewall profile..
im running Toyo Trampios and they're just nice, Potenzas rubbed and left rubber on the coilovers :(
hope this helps somewhat
Hi mike..
Thanks bro..
Means 235/40 or 45 shouldnt b a problem aight?
Did u knock ur sidewall?
Wonder if run wif 255/35 or 45...
aiyohh... tight budget to buy
adjustable loh...
....other guru's..?
~take k mike...
I thought you sold di your A31?
I ran 8 inch front and 10 inch rear on 235/40/17 F and 255/45/17 but with TEIN HA all clear except for the front cause offset not right......18mm spacers solved the problem.
Hi shean guru..
My A31 sold edi... ;)
Question is 4 my knowledge only.. :) hehehehehe..
For rear... did u mods ur wheel arch
aa shean? Knock or sumthing?
Front need spacer huh.... did u do any
mods on wheel arch??..
...aiyooh..need to recce halfcup shop
laaa like that??
Thanks shean.. :)
~take k mike..
no mods done to the arches.If your wheels offset is right then it should not be a hassle just that my front has a funy offset hence the spacers.
If you are going 17x8 and 17x9 I'd advice you go coilovers for the tyres to clear the dampers
It really all depends on your rims... the offset has to be right... i am using 17x9.0 on the rear with 245/45 and there is no rubbing the tyre on the shocks or the guard... i think mine is offset 34... just nice... i think the most i'd do is to roll the lip on the guard in just a bit...
9s give a nice fat wide look to the A31! :)
Hi mike...
Thanks GURU'S...
Think might get 9.5" for rear would b nice..
8.5" run for front should b ok... might need spacer
onli...
THANKS AGAIN MANN!!...
~take k mike..
