Walbro internal fuel pump
silvertop madness
Hye there veterans, just wanted to ask something regarding fuel pumps, im using a ae100 corolla with an internal racing fuel pump Walbro 255, can i use my car until the tank is below half? because my mech told me if possible don't let my car run below den half tank..any opinions guys??
normal driving.....should be ok with half tank.
For spirited driving with half tank (assume your tank is still ori), the movement (lateral acceleration, high power and demanding condition like drifting) of the car make the fuel in the tank to slush around....this could possibly cause accidental ingestion of air in the fuel pump/line....and may cause fuel temporary exhaustion to the engine. I think this is your mech's concern.
If you are concerned about possible sucking in air in the fuel line, just install a fuel surge tank, or sometimes it is called a swirl pot.
Thanks for the info bro...but i think a fuel surge tank would't be too necessary as my car is not fully modded..my mods are just da Walbro fuel pump, FPR, trumpets and exhausts..if i were to go make it a drag beast, my ill reconsider da surge tank :biggrin:
i think ur mech is more concerned about the fuel pump burning out when the fuel slushes around....and not cooling the fuel pump enough
happens quite abit to walbros...theres even a thread here on ZTH where someone disected it and took a look.
feel free to google and see
but for better clarification... ask ur mech why la
