Walbro fuel pump type
SimpleGuy
Hi everybody, i juzt wonder is there any WALBRO fuel pump larger than 255lph-hp? and is it when the pump is working, there will b a loud sound produce from the pump?
i'm using Walbro 255 LPH, the sound aar, how can i define here by words?? suggest u go listen to one which have installed, i'm staying in penang and ur in butterworth, if u can get a trip up to northern garage u can listen to my fuel pump....
hi kenneth, u from which part of penang?
hi wajafly, standard mivec without mod jz need to use back the halfcut pump is enuf, jz need to add on a FPR.
Thank you simple guy. The FPR set how many Psi? I use Arospeed FPR. Boleh pakai kah? And actually how FPR helps Mivec or any other engine in terms of performance?
