Waja 1.6A when up hill problem
achmedrauff
bump bump
My Waja when go up hill, genting, cameron, fraser... got smoke coming out of the engine bonnet but the temperature stay below 90 C... i got very scared when driving up hill every time. i even check the water level in the radiator but it is still full even when cold down. what is happening?!? the smoke coming out from the bonnet just freak me out every time. Help~:bawling:
it could be a few number of causes...could you be more specific and isolate from which part exactly the smoke is coming from?
bump bump
confirm smoke??... not steam or whatever??...
if smoke, check ur exhaust manifold for any sign of leaks.... if steam, check ur radiator and cooling system....
No sure if it was smoke or steam, cause it just come out of the bonnet and when I stop and open the bonnet it doesn't happen anymore. that is weird cause i check the water level was still full. So i assume is a bit overheat and cold air outside making the steam/smoke, but my temp showing normal level < 90 Celsius. my Waja is A1.6.
i think i will get the exhaust manifold and radiator n cooling system check but i notice that if my car not moving the fan is also not spinning, is that normal?
engine oil leaking izzit?..check is there is any engine oil stains.
las time my car head cover gasket leaking also like tat..the engine oil leak to ekzos and u can see smoke :) oil burning
