vtec oil pressure
cool_H22A
vtec fuel pressure reading
hi....want to ask what is the fuel pressure actual reading for vtec engine.?
1.in cold start?
2.idling?
3.cruising?
i have using a SARD fuel pressure regulator for long time d, then just install a defi fuel pressure sensor on it....the reading was different from you all.......the reading at the defi meter not in psi or bar... below are my fuel pressure reading
1.ignition on 3.6
2.cold/warm start 2.8
3.idling 2.8
4.cruising 2.8-3.0
the reading is in kgf/cm2..........................so i want to know is the defi meter reading is correct or there is something wrong with my fuel pressure.
thanks
First of all...
1. Oil prresure and
2. Fuel pressure is different things....
If you are talking about fuel preassure... it should be around 3-3.5kgf... as standard..
