vr4 speacialist pls help!!
calvinpkk
i am driving the putra with vr4 220....wat the problem for my car now is the check engine light will appear, when the light appear, the car will starting "chok". i have send the car to 2 workshop and change the air flow sensor, ecu, wiring, plug cable, plug and coil.....after all this thing done still facing the same problem......have anyone have the experience will this or do you know where got the speacialist for vr4........thank for help!
hw bout fuel pump :P n ignition lolx
but i guess u fix an MUT u can catch the problem , isnt tht easier ?
hmmm... last time just before my ECU "kong" funny things happened to my car.
maybe the damn japanese capacitors is leaking in your ECU. while you are at the ECU u may want to check the engine relay as well.
hey there i got exactly the same prob last time...im also driving vr4 220...i send it to my mec i dunno wat he did but now its fine till now...all i noe is i chnage to ngk spark plugs and ngk cables...then some tuning the engine again or soemthing like that.. he talk to me in chinese but im banana..understand abit oni...
calvin aaa.....
ok everythings done....
do u noe the earth cable connect to the batteries??
right, make sure u'r earth batteries cabble that connect to
body is connected perfectly to u'r cars body, seek 1st laaa
if still arise, we'll try somethin' else...
brother , wat is MUT? sorry to ask coz i really don't know wat is that....
thank, i will try to told my foreman to check it.....see how the result 1st....
sounds more like wiring problems..
VR4 wiring not meant for Protongs...itz alwiz a mix-n-match..they're never perfect..
go to a wireman to check..
and also explain in detail your meaning of 'choke'...
