Volvo Malaysia Launches Locally Assembled ES90 Electric Sedan
Newspeed
Volvo Car Malaysia has officially introduced the ES90, its first fully electric flagship sedan. Locally assembled in Shah Alam, the ES90 features a high-riding "three-box" silhouette that combines sedan proportions with the ground clearance and seating position typically associated with crossovers.
Exterior Design and Practicality
The ES90 marks a shift in Volvo’s design language for sedans, emphasizing aerodynamic efficiency with a drag coefficient of 0.25.
  • Signature Lighting: The front features the "Thor’s Hammer" LED pixel matrix headlights. At the rear, the C-shaped LED lamps are joined by vertical LED light strips embedded directly into the rear windscreen, a detail shared with the EX30 and EX90.
  • Hatchback Versatility: Unlike a traditional sedan with a trunk lid, the ES90 uses a wide-opening fastback-style power tailgate. This provides access to 424 liters of storage, which expands to 904 liters when the 40/20/40 rear seats are folded.
  • Stance: The car sits on a 3.1-meter wheelbase and comes standard with 22-inch five-spoke diamond-cut alloy wheels. It features a ride height of 203 mm (178 mm ground clearance).
Architecture and Performance
The ES90 is the first Volvo model to utilize 800-volt architecture, significantly improving thermal management and charging speeds.
  • Battery & Range: The Malaysian-spec model features an 88 kWh battery (usable) providing a WLTP range of up to 651 km.
  • Charging: It supports DC fast charging at rates up to 350 kW. Under optimal conditions, a 10% to 80% charge takes approximately 22 minutes, while a 10-minute top-up can add up to 300 km of range.
  • Drivetrain: The single-motor rear-wheel-drive setup produces 245 kW (333 hp) and 480 Nm of torque, enabling a 0–100 km/h sprint in 6.6 seconds.
Interior and Technology
The cabin is designed around a "Scandinavian living room" concept, focusing on minimalist physical controls and high-quality materials.
  • Infotainment: The dashboard is dominated by a 14.5-inch portrait-oriented touchscreen running a Google-built-in OS. Unlike the EX90 SUV, which uses a round controller, the ES90 features a physical rotary dial on the center console for multimedia functions.
  • Computing: It is the first Volvo powered by a dual NVIDIA DRIVE AGX Orin configuration, providing the core computing power for its "Safe Space" technology. Notably, the Malaysian-spec model does not include a roof-mounted LiDAR sensor.
  • Cabin Comfort: Features include an electrochromic panoramic glass roof (tunable transparency), a 25-speaker Bowers & Wilkins audio system with a dedicated "Abbey Road Studios" mode, and ventilated Nordico upholstery.
Pricing and Availability
The Volvo ES90 is priced at RM339,888 in Malaysia. It is available in four colors: Vapour Grey, Crystal White, Denim Blue, and Onyx Black. The first 100 customers to book by March 31, 2026, will receive a 2% early-bird incentive.
