Using back saga gearbox for 4G61 engines...
merz2
ive found this very rare specis of halfcut but in auto transmision...so i want to ask if i want to use back my saga gearbox...what should i add on or modify...any suggestion for other gearbox that can fit saga like wira 1.6 or perdana...thanks!!
errr i see saga use WIRA dashbord n gear console....
So is it do like that need big project??? bcs syiok mahh use saga hv wira interior feel...
not a problem , you can use back your saga gearbox but you need to do some modification on the clutch cover if you want to remain the 9" clutch . once you use the saga gearbox then you must use back your ori driveshaft .
