Gearbox Saga BLM
beartokun
Hi all,
since 2008 im using Proton Saga BLM 1.6 taxi spec but not a taxi........ now it time me to upgrade my car for more performance.
here are the thing that i already install it into my car:-
1) 4-2-1 Extractor
2) Highcam 262
3) Adjustable Campulley
4) EMS-1 Piggyback
now i thinking about using LSD into my car
i need suggestion from u guys should i put aftermarket LSD add-on or change the gearbox to MIVEC CK?
are MIVEC CK gearbox can put into my Saga BLM if can is there any other modification needed to install it?
so guys please help me...:confused::confused::confused::confused:
Do anything except don't ever transform your BLM into this: :biggrin:
why i need to change it because
1) cost: aftermarket LSD is 900++ plus workmanship is around 200++ & if im buying CK gearbox is around 1500++ and gear ratio also i can select which one i need........but right now i'm confusing if i choose the first step maybe i will added additional cost .......but if i choose the second one also added additional cost of change the gear lever and much more.....so i need opinion from your guys.......the main reason is i want to join "SNF"........
I thought saga blm final drive is 4.7 why want to downgrade to 4.62?correct me if im wrong.anyway lsd is sweet,,u can feel the inner pull every corner but must be carefull on wet and dont take full lockif buying ck gearbox.
