check all the hose going to your fuel tank , suspected you have a bent hose which makes the fuel to spill out when filling it fast . i had that problem long time ago after my conversion .Originally posted by wildboar@Jan 14 2005, 12:22
i read somewhere sometime ago that some (not all) users of 4wd fuel tanks encounter this problem when pumping petrol...its spills or splashes out...so have to pump slowly...
is this true?? if so, wat causes this ar?? the pipe going in different route ar??
