Urgent Help-Wira Servo Problem
NSkyline
Dear proton wira owners, I own a proton wira 1.5 Auto year 2001:regular_smile: . My
milage now is at 127, 000. Somewhere last year i sent my car to eon SC at
glenmarie for a routine service. After collecting the car i drove and to
my shock there was no power at all:baring_teeth: . Even when i reverse, the car barely
moves. I took in back to eon for tuning again. An Indian mechanic told me
somebody had messed up my tuning. So he re-tuned the car again. The power
was awsome..better then before:_: . But he told me that my car servo has
problem:cry_smile: . The moment air-cond is on, vibration gets louder. I changed my
engine mounting too as there was a crack but not much changes. The
vibration is still there. When i start my car the timing also goes a
little high but mechanic said if i make it lower vibration will get worse.
I just need to confirm, is the vibration caused by the servo problem? Is
there anything else i need to check regarding the vibration? Vibration is
bad when i'm reversing but during normal driving its ok. But if car is at
D and stationary also quite bad. Eon told me it costs around RM 900 to
change the servo.Can someone pls help to explain my situation...thank you.
