unbalance kancil
s.l.k
dear all,
recently i found tat my kancil is unbalance...the rear of the driver side is much lower than the left side.i hav change all of my absorber and coil spring,but this problem stil exist.it makes me very pening kepala.
so can any pro or pakar kancil PLEASE give me some advise?
thanks....
yea. i also did face the same problem too at tat time.. sold away the car edi. i think it's the weakness of kancil maybe..
Yes, I also share the same problem. Mine already change 2 pairs of front absorber, 3 pairs of rear absorber and 2 rear brand new spring.
Some said might be the rear arm bushing, so kena change that bushing all 4 of them....
Now still the kancil driver side is lower than the passenger side about 4 inch..
Still struggling to settle the problem. Any sugeesssion/ guide? :smokin: hahaha :nurse:
did u check the ori spring from Daihatsu or from Perodua?
coz what I know that there is extra 1 round at the right side to make sure it balance.. if u change to aftermarket spring.. it will be like that...:burnout:
Yo mag,
1st thanks for the info
I'm not sure but so far there is no complains from anyone who use the aftermarker spring. I'm using the L2 spring and absorber as for the my front suspension.
Any other suggestion on this matter of unbalanced kancil.... [ / ] :banghead:
my mom's kancil since 1996, its ok coz changed to 13inches after mkt rims...i try looking at it...balanced...
bro, u mean the front lower arm?u having the same problem b4?my friend 2007 oso unbalance...
thanks for u advise...
Already change the Front Lower arm, brand new plus the anti roll bar bushes... Yet still the left side is higher than the driver side.... Probably Chasis Body?:banghead:
i also confront with the same prob.. more weird, my left side is also higher.. same as yours.. but my prob occur after i accident..
Bump:
u feel unbalance or u look unbalance.....if look unbalance maybe...ur bumper not balance.....other than tha:rolleyes:t i dunno wat the answer huhuhu...
Yalor, mayb ur bumper?
Try measure the clearance of ur car body from ground and tyre from wheel arch as well.
Find other foremen to look at ur car also.
Just a reminder, kancil real spring hv rubber bushing on both ends. There are 2 type thick and thin ones. Make sure u change them and ... juz double check if they accidentally left part of the old 1 inside.
