R resh9999 Known Member Senior Member Apr 25, 2014 #1 Hi guys, with the existing standard tyre size, can i fix a wider tyre at the rear and standard size at the front
DanzEterna Moderator Moderator Senior Member Apr 25, 2014 #3 should be able too but abit funny la. unless your rims are 8jj
R resh9999 Known Member Senior Member Apr 25, 2014 #4 I am not very sure of the size but slightly wider at the back. My rims are stock. Planning to change rims at Kings of Rims Shah Alam.
stutzedward 3,000 RPM Senior Member Apr 25, 2014 #5 Make sure all rolling diameter of the tires are the same as our cars are awd. If the difference is too big, I am not sure if it'll create problems to the gear sync. Just my personal opinion.
C cytien Known Member May 6, 2014 #6 any good tyre to recomment for 18inch ? cheap and affortable .. no $$$
4gbanger 1,500 RPM Senior Member May 6, 2014 #7 achilles atr sport - rm 3xx.. now they are out with atr sport 2 cost 5-10 bucks more..
vr2turbo ((( God Level 30,000 RPM ))) Helmet Clan Moderator May 6, 2014 #8 resh9999 said: Hi guys, with the existing standard tyre size, can i fix a wider tyre at the rear and standard size at the front Click to expand... Why? You cannot rotate the tyres, better off with same size all round. Want wider upgrade all 4 tyres....
R resh9999 Known Member Senior Member May 6, 2014 #9 Make sense. Thanks Sent from my GT-I9500 using Tapatalk
4gbanger 1,500 RPM Senior Member May 6, 2014 #11 i'm sure jalan kapar tyre shop now already receive their stock for atr sport 2.. last few month i went there, not yet..
stutzedward 3,000 RPM Senior Member May 7, 2014 #12 Ah Kit rim @ Shah Alam. You can google. He advertises a lot in Mudah. Cheap rims and tires there. Very good business.
