Two SVT problems. One Major/One Minor
BudakSiol!
Dear members & sifus,
Just bought myself a corolla with silvertop engine. Am Happy with it BUT there are two problems.
Minor Problem - Idles is not stable. Sometimes it stays at 2000rpm or 1500rpm and sometimes as low as 500rpm. With or without aircond it's the same.
Major Problem - The old user of this car welded cranskhaft pulley! Can give me worse case scenario of what is wrong with it? Mechanic said might have to pull down the engine... Attached are photos for your diagnosis! Thank You in advance!
http://i278.photobucket.com/albums/kk118/ae85lebin/crankoilsump1.gifhttp://i278.photobucket.com/albums/kk118/ae85lebin/crankoilsump2.gif
minor problem... can check the idle valve, throttle body c.. clean it. shud be ok the idling..
major problem..
WTF.. who the F##K is tat previous onwer mechanic... crazy ar.. welding it mati .. this make u no choice to turun the engine to fix it..
mayb also can buka the bottom engine n turun crankshaft only.. but if tukar crankshaft need to do many thing..
but u better dun fix it first until very last step.. then buka n overhauk lo.. hahahhaha
sad to hear tat..
i think the crank shaft is the problem at the 1st place.... if not why the old mech weld it... maybe it loose and hv no other choice (other than change it) so they weld it.
my opinion, maybe your two problems are link. maybe the pulley maybe not stable (balancing like balancing tyre at tyre shop) and my skip/slip belt so your idling may smooth or rough....
=>this just an assumptions<= correct me if i'm wrong here
Thanks guys.
I hope this will be the only major problem to drop on me laaaa adoi. I have to turun the engine now since timing belt also can't be change! Real :thefinger:!
bro..I think that minor problem from that the old owner welding that cranksyaf pulley..that cranksysf pulley have a rubber damper..after welding that rubber was bakar ..maybe after u clean your thottle body u can check timing with timing light...make sure reading marking angle 8-10
hi,
for your minor problem, first u can try to clean up the TB, i used to have that problem before, then i did clean the TB, the mechanic pull out the whole TB and clean it, put it back, do some tuning, and its ok ..
actually for SVT to have unnormal RPM was slightly normal .. sometime it goes up till 1.5 - 2K, then come to normal ... but for me, never drop to 500 rpm ...
may be u can also replace the timing belt if the provious owner not done it yet ...
just my two cents ..
