Turning Your Camera Upside Down ? - READ
sakuraguy
5,000 RPM
Get Better Portraits by Turning Your Camera Upside Down?
File under oddity: Website Digital Camera University says that you can take better portraits (that is, pictures of people's faces) if you turn your digital camera upside down.
Why? It has to do with the location of the flash: Since it's mounted above the lens it creates slight shadows by the way the light bounces off the lines on your subject's face, which makes wrinkles and blemishes look more noticeable than they should. By turning the camera upside down, the light (now coming from beneath the lens) hits the face at a slightly different angle, creating a slightly different image. That's the theory, anyway.
Looking at the close-up on the site's sample images you can indeed see the difference the writer is talking about if you look at the lines around the model's eyes fairly closely. But I tried it myself to make sure this wasn't a hoax. When shooting an adult face, it was very clear that the upside-down tip did indeed reduce the appearance of lines. The crease around the mouth was noticeably less visible in the upside-down shot I tried than in the regular portrait. However, there was one unintended side effect: The upside-down shot made her face look much redder than it should have, for reasons I can't explain.
I also tried the trick on my four-year-old daughter, but since she is not yet jaded and beaten down by the cruel world, she doesn't have facial lines. I couldn't tell the difference between the side-by-side shots of her.
As the linked site itself notes, the effect is subtle and difficult to see, but it does exist. Is it something I'll do regularly? Probably not, unless repeated portraits keep turning out badly. But it's a neat little party trick that you ought to try at least once when snapping a shot of grandma.
Turn Your Digital Camera Upside Down For Better Portraits.
Flipping your digital camera over for better portraits is a technique you won’t find in your digital camera owners manual.
http://www.digitalcamerau.com/wp-content/uploads/2006/08/flash2.jpg
If you are using your compact digital camera and flash for shooting a portrait here’s a suggestion that you might never consider, turn your camera upside down.
Believe it or not by turning your camera upside down impacts how the light from the flash illuminates your subject. Most people have circles under their eyes and when you turn your camera upside down the flash hits the skin at a different angle and helps diminish the circles and makes them look younger.
The first photo was taken in the normal position with the flash on top.
http://www.digitalcamerau.com/wp-content/uploads/2006/08/Flash-Normal.jpg
http://www.digitalcamerau.com/wp-content/uploads/2006/08/Flash-Full-Upsidedown.jpg
In this second photo I flipped the camera upside down.
http://www.digitalcamerau.com/wp-content/uploads/2006/08/Flash-UpsideDown.jpg
http://www.digitalcamerau.com/wp-content/uploads/2006/08/Flash-Full-Right.jpg
Notice in the second photo because the angle of the light from the flash is now hitting her skin at a different angle it helps reduce lines and is a more flattering light.
True, the effect is subtle. However, if you show someone a photo of themselves using this technique they will like the upside down flash version better, guaranteed.
Also, these photos are REALLY closeup! In a normal proportioned photo the effect is even more flattering.
Give it a try!
Source : www.digitalcamerau.com
thanks for sharing. persoanlly I can see the difference. Maybe it is there but a bit subtle for me to notice, for a guy, I mean.
Anyway, you can never know abt this matter when it come to gerls. They tend to see many things that guys don't realised......like nose hair...hahahahah
Er, the distance between your average point-and-shoot's flash lens is so small, it woudnt make a difference. Or maybe, just maybe, people should learn(yea I know, its crazy) how to use a camera?. Flip it however you want, the physical state of the lens & flash isnt going to change.
The only real thing you can do is diffuse the light from the flash.
