Turbosmart wastegate (original)
Over Boost - Motorsports
Beyond 20,000 RPM!
TURBOSMART WASTEGATE (ORIGINAL)
Turbosmart Ultra-gate 38MM Wastegate
Part Numbers:
BLUE: TS-0501-1010
BLACK: TS-0501-1011
DESCRIPTION: 38mm external wastegate. Small and lightweight, the Ultra-Gate38 provides high-end features and build quality at an entry-level price.
APPLICATION: Suitable for all turbocharged vehicles with an external wastegate turbo system. Street and racing applications. Flanges suit 1.50” outside diameter pipe.
SUPPLIED WITH: 7 psi spring (fitted), valve seat, 2 x stainless steel gaskets, mounting bolts and 2 x 1/8 NPT vacuum fittings. Kit Builder Packs available to customer specifications.
Turbosmart Comp-Gate 40MM Wastegate (NEW DESIGNED)
Part Numbers:
BLUE: TS-0505-1005
BLACK: TS-0505-1006
DESCRIPTION: Turbosmart’s brand new 40mm external wastegate was designed to fit into tight engine bays while still offering superior flow and heat handling capabilities. The revolutionary new actuator housing is 25% smaller than our current range and allows for easy spring changes and gives the ability to index the cap orientation in 12 different positions.
APPLICATION: Suitable for all turbocharged vehicles with an external wastegate turbo system. Street and racing applications. Flanges suit 1.75” outside diameter pipe.
SUPPLIED WITH: 7PSI Spring (installed), Inlet and outlet Weld Flanges, Inlet and outlet V-Band clamps, Valve seat, 2 x 1/16th blanking plugs, 2 x 1/16th Vacuum nipples, Locking Ring removal tool. Kit Builder Packs available to customer specifications.
Turbosmart Hyper-Gate 45MM Wastegate
Part Numbers:
BLUE: TS-0504-1001
BLACK: TS-0504-1002
DESCRIPTION: 45mm external wastegate. Turbosmart’s new 45mm external wastegate offers class-leading flow path and temperature resistance in a compact and lightweight package.
APPLICATION: Suitable for all turbocharged vehicles with an external wastegate turbo system. Suits 1.75” outside diameter pipe. Fits all popular 44mm flanges.
SUPPLIED WITH: Supplied with a 7psi spring (fitted), inlet and outlet weld flanges and V-band clamps, valve seat and 2 x 1/8 NPT vacuum fittings. Kit Builder Packs available to customer specifications.
Turbosmart Pro-Gate 50MM Wastegate
Part Numbers:
BLUE: TS-0502-1001
BLACK: TS-0502-1002
DESCRIPTION: 50mm external wastegate. Combining a compact body, superior flow path and high temperature resistance makes the Pro-Gate50 a market leader in its sector. Shielded diaphragm housing ensures excellent heat handling capabilities.
APPLICATION: Suitable for high performance turbocharged engines with an external wastegate turbo system. Suits 2.00” outside diameter pipe. Fits older-style Pro-Gate48 and Power-Gate50 flanges.
SUPPLIED WITH: 7psi outer spring (fitted), 10 psi middle spring, inlet and outlet weld flanges and V-band clamps, valve seat and 2 x 1/8 NPT vacuum fittings. Kit Builder Packs available to customer specifications.
Turbosmart Power-Gate 60MM Wastegate
Part Numbers:
BLUE: TS-0503-1001
BLACK: TS-0503-1002
DESCRIPTION: 60mm external wastegate. With a superior flow path and high temperature resistance the Power-Gate60 is a market leader in its sector, outperforming all similarly sized wastegates. The shielded diaphragm housing ensures excellent heat handling capabilities.
APPLICATION: Suitable for extreme performance turbocharged engines with an external wastegate turbo system. Suits 2.50” outside diameter pipe.
Over Boost - Motorsports are AUTHORIZED DEALER for Turbosmart Products and all our turbosmart products comes with Genuine Hologram Turbosmart Sticker
We also have all the replacement parts needed such as v-band clamps, springs, diaphragm, valve guide, valve seat and more
PRICE
Turbosmart Ultra-gate 38MM Wastegate = RM 1,149
Turbosmart Comp-gate 40MM Wastegate = RM 1,399
Turbosmart Hyper-gate 45MM Wastegate = RM 1,599
Turbosmart Pro-gate 50MM Wastegate = RM 2,299
Turbosmart Power-gate 60MM Wastegate = RM 2,799
http://www.overboost-motorsports.com/zthlogo.gif
CONTACT DETAILS
Address - No 28A, First Floor, Jalan PJS 11/7, Bandar Sunway, 46150, Petaling Jaya, Selangor, Malaysia (same row as N1 Racing, beside WRC Lighting)
E-Mail - [COLOR="Black"][email protected][/COLOR]
Tel - +603-5611 6628
Mobile - +6012-955 1800
Blackberry Pin - 2284DEF5
Website - OVER BOOST - MOTORSPORTS
MSN - [COLOR="black"][email protected][/COLOR]
Skype ID - overboost-motorsports
Facebook - Over Boost - Motorsports | Facebook
Mudah - PRO Niaga: Over Boost - Motorsports
CLICK HERE FOR CONTACT FORM
