Turbosmart E-Boost Street Electronic Boost Controller 40psi
Over Boost - Motorsports
Beyond 20,000 RPM!
Racing technology for the street
E-Boost STREET is an electronic boost controller aimed at the street performance market. It features many boost control capabilities found on its big brother – the e-Boost2, continuing the e-Boost tradition of providing class-leading boost control, value for money and no nonsense features.
New features include 40psi max boost operating pressure and an auxillary output.
2 Boost Settings: easily selected via the “turn-and-push” button. An external switch can also be used to change between boost groups if required.
Boost Correction Factor: eliminates boost drop off at high RPM.
3 Segment Display: with adjustable brightness can be configured for PSI, KPa, or BAR and will flash when warning of over boost shutdown or rev limit, allowing the unit to be used as a boost gauge, tachometer, or a shift light.
Dimensions: W:80mm H: 25mm D: 95mm (can mounted within a 1/4 DIN size opening)
Maximum Boost Level: 40PSI / 2.72BAR.
What’s in the box: e-Boost STREET control unit. Wiring loom + installation kit
Solenoid with mounting bracket and vacuum fittings, vacuum hose and hose clamps
PRICE
Turbosmart E-Boost Street Electronic Boost Controller 40psi = RM 2,319.90
Over Boost - Motorsports are Authorized Dealer for Turbosmart Australia Products
http://www.overboost-motorsports.com/zthlogo.gif
CONTACT DETAILS
Address - No 28A, First Floor, Jalan PJS 11/7, Bandar Sunway, 46150, Petaling Jaya, Selangor, Malaysia (same row as N1 Racing, beside WRC Lighting)
E-Mail - [COLOR="Black"][email protected][/COLOR]
Tel - +603-5611 6628
Mobile - +6012-955 1800
Blackberry Pin - 2284DEF5
Website - OVER BOOST - MOTORSPORTS
MSN - [COLOR="black"][email protected][/COLOR]
Skype ID - overboost-motorsports
Facebook - Over Boost - Motorsports | Facebook
Mudah - PRO Niaga: Over Boost - Motorsports
CLICK HERE FOR CONTACT FORM
