Turbochargers
Turbochargers
bizzy_b_28
Turbochargers
FREE MAX BOOSTER
2-in-1 octane booster and fuel injector cleaner!
• Restores engine's power performance.
• Maintains cleanliness of fuel system and protects against corrosion and rust formation.
• Cleans deposits on fuel injector for better and more efficient combustion.
• Reduces pollutant emission to the environment.
• One measure treats up to 150 litres of petrol or use once a month for normal usage.
• 250ml.
http://img707.imageshack.us/img707/4395/218837b.jpg
Uploaded with ImageShack.us
GT15 T15 Turbocharger
Condition - New
Air Inlet 1.75"
Air Outlet 1.5"
Bearing Wet Floating Bearings
Wastegate 13PSI
Compressor .35 A/R
Compressor Compressor Wheel Exducer: 49mm, Inducer:36.4mm
Turbine Wheel Exducer: 34.95mm, Inducer:41.35mm
Works for:Perfect for Small Engine, 2-4 Cylinder.
6 Months Manufacturer Default Warranty
Price - RM 1200
http://img64.imageshack.us/img64/5105/gt15t15.jpg
CT 26 Turbocharger
Condition - New
1988-1989 Toyota Celica All Trac 3sgte Engine Stock CT26 Turbo Replacement Turbocharger!!
Direct Bolt on Replcement for stock turbo.
Fully balanced wheel for best throttle response.
2.4" inlet for low back pressure.
Bronze bearing used for fast turbo spool & low friction.
High performance bronze thrust collar bearing used for low friction.
High performance cromoly oil ring's used for longer life expectancy.
100% Brand New.
Compressor Specs :
42.20mm minor
64.95mm major
CT26 Tubine Housing
Turbine Specs :
51.90mm minor
67.55mm major
Exhaust Outlet Flange with CT26 single scroll 4 bolt design
Price - RM 1500
http://img189.imageshack.us/img189/1097/ct26.jpg
GT28 T28 Turbocharger
Condition - New
• 100% BRAND NEW,REALLY HIGH QUALITY.
• THIS GT28 TURBO IS DIRECT BOLT ON UPGRADE FOR STOCK SR20DET/CA18DET TURBO.
• SIZE: 3.0" INLET,2.0'' OUTLET.
• COMPRESSOR:60 AR; EXDUCER:71.32MM; INDUCER:54.28MM.
• TURBINE :84 AR; EXDUCER:52.90MM; INDUCER:45.47MM
• TURBO MANIFOLD FLANGE: T25/T28 FLANGE; DOWNPIPE FLANGE: 240SX 5 BOLTS FLANGE.
• TYPE OF COOLING: OIL COOL ONLY.
• TYPE OF BEARING: WET FLOAT BEARING.
• SET AT 14.5 PSI AND CAN MAX UP TO 25 PSI,MAX UP TO 400HP
• NO INCLUDING INSTRUCTION. PROFESSIONAL INSTALLATION IS HIGHLY RECOMMENDED
Price - RM 1300
http://img861.imageshack.us/img861/8665/gt28turbo.jpg
T25/T28 Turbocharger
Condition - New
APPLICATIONS:
• Fits Turbo Application: Requires manifold with T25 OR T28 FLANGE
Features:
• T25/T28 TURBO UNIT
• Utilize internal wastegate
• Made of Quality Cast material
• Oil Cooled Comp.
• 8 Psi internal wastegate
• Working press is 5 to 30 PSI
• Turbo: .63 A/R Turbine
• Compressor Wheel: Inlet is 2", 37.8 Inducer, 59.7 Exducer, 40 trim and .42 A/R
• Turbine Wheel: 52.9 Inducer, 45.47 Exducer, 73 trim and .86 A/R
• 5 bolt downpipe flange
• Suggested for 1.6L and 2.3L engine, up from 160-270HP
• All flanges pictured are included as well as internal wastegate
Price - RM 1200
http://img824.imageshack.us/img824/82/t25t28.jpg
TDO5-H 16G Turbocharger
Condition - New
• 100% brand new. Never been tried or installed.
• Supports up to 360HP and deliver 580 CFM.
• Easy to install, Direct replacement to most DSM Applications.
• Type of Wastegate - Internal Wastegate
• Compressor Wheel - 48.3mm / 67.9mm Diameter
• Turbine Wheel - 49.2mm / 56mm Diameter
• No instructions included. Professional installation is highly recommended.
• Modification of turbo manifold might required to some application.
Applications:
• For All 4G63 2.0L Engine
• 91 / 92 / 93 / 94 / 95 / 96 / 97 / 98 Mitsubishi Eclipse GSX GST
• 91 / 92 Mitsubishi Galant VR-4 2.0L
• 90 / 91 / 92 / 93 / 94 / 95 / 96 / 97 / 98 Egale Talon 2.0L
Price - RM 1400
http://img202.imageshack.us/img202/8339/td05h16g.jpg
TDO5-H 20G Turbocharger
Condition - New
Core Spec : TD05H-20G with 360 degree thrust bearing.
Compressor Housing: Larger 0.60 A/R
Compressor Wheel: TD05-20G 56.6mm
Turbine Wheel: 48.8 mm
Water & Oil-cooled.
oil feed M12*1.25
oil drain 2*M6*1.0
water in/out M14*1.5
MAX HP approx 460HP
Application: Subaru Impreza WRX/STi EJ20/EJ25 Engines
Price - RM 1600
http://img848.imageshack.us/img848/8493/tdo5h20g.jpg
FOR FURTHER INQUIRIES:
Call (HP): 012-3505832
(OFF): 03-77811481
Or Drop-By:
49D, Jalan PJS 1/48, Petaling Utama 7,
Off Jalan Klang Lama, 46150, Peataling Jaya,
Selangor, Malaysia.
(OFF): 03-77811481
Or Drop-By:
Selangor, Malaysia.
(OFF): 03-77811481
Or Drop-By:
Off Jalan Klang Lama, 46150, Petaling Jaya,
FREE MAX BOOSTER
• 250ml.
(OFF): 03-77811481
Or Drop-By:
We have shifted to Sunway..
For further inquiries:
MOB : +60123505832
OFFICE :0356361481
Or Drop-by:
No.6-M, Jalan PJS 7/20B,
Bandar Sunway,
46150 Petaling Jaya
Selangor, Malaysia
MOB : +60123505832
OFFICE :0356361481
Or Drop-by:
Bandar Sunway,
46150 Petaling Jaya
Selangor, Malaysia
MOB : +60123505832
OFFICE :0356361481
Or Drop-by:
Bandar Sunway,
46150 Petaling Jaya
Selangor, Malaysia
MOB : +60123505832
OFFICE :0356361481
Or Drop-by:
Bandar Sunway,
46150 Petaling Jaya
Selangor, Malaysia
MOB : 0172585085 / 0123505832
OFFICE :0356361481
Or Drop-by:
Bandar Sunway,
46150 Petaling Jaya
Selangor, Malaysia
Operating Hours:
Mon - Fri
10.00am - 7.00pm
Sat
10.00am - 5.00pm
OFFICE :0356361481
Or Drop-by:
Bandar Sunway,
46150 Petaling Jaya
Selangor, Malaysia
Operating Hours:
Mon - Fri
10.00am - 7.00pm
Sat
10.00am - 5.00pm
OFFICE :0356361481
Or Drop-by:
Bandar Sunway,
46150 Petaling Jaya
Selangor, Malaysia
Operating Hours:
Mon - Fri
10.00am - 7.00pm
Sat
10.00am - 5.00pm
OFFICE :0356361481
Or Drop-by:
Bandar Sunway,
46150 Petaling Jaya
Selangor, Malaysia
Operating Hours:
Mon - Fri
10.00am - 7.00pm
Sat
10.00am - 5.00pm
