Did you know turbocharger works as a mechanical sensor for the engine... how??
which mean when it damage,it can tell us what actually happen inside (by turbo post postmortem) the engine or what made the turbo failure...
for example...
"The bearings are usually destroyed by either oil contamination, oil starvation or oil coking...Heavy grooving or pitting of the bearing surface usually indicates dirty oil, possibly due to inadequate oil filtration. Check for a plugged oil filter. Once an oil filter becomes clogged and it's bypass valve opens, unfiltered oil flows to the turbo and the rest of the engine.
"The condition of the compressor and turbine wheels... Cracks can be the result of metal fatigue, but nicked bent or damaged blades (turbine wheel or comp wheel) can only be caused by foreign objects. If the compressor blades are badly eroded, unfiltered air has been entering the intake system. Check for a missing, torn or poor fitting air filter...
Moral of the story
- Don't F**k Turbo Repairer or Don't blame turbo..check the engine 1st..then later baru F**k them if necessary but remember we r Malaysian-- dont f**k2 --No good
*proud to be Malaysian
cheers..
for example...
Moral of the story
cheers..
im a lover ma.. not a fighter..
