tsd boron nitride thermal coating
kent25
https://www.zerotohundred.com/forums/attachments/214724.vBhttps://www.zerotohundred.com/forums/attachments/217544
tsd boron nitride coating is revolationary coating that help to improve heat exchange efficieny.Where TSD coating is applied,it will improve tghermal managerment by reducing internal temp. by 10% - 20% effectively.
It can be applied to virtually any surface/material that can benefit form better thermal management or surface protection.
Applying the TSD thermal coating effectively extracts heat form the heat source. The heat is quickly directed away and cooled by temp. differences. credit card accepted
In addition,the thermal coated surface forms a white graphite-like protection layer against oxidation.The increased surface area will effectively allow more air-surface contact for cooling.
The coating process does not require special equipment,dries quickly,can withstand heat of up to 200 degrees celcius and easy to use.
Car component to apply:
- intercooler call 017 6241098
- radiator
- AC conensor
- turbo kit
- engine
- brake caliper
- valve cover
- extractor
- intake manifold
- and many more..... more itemhttp://www.zerotohundred.com/newforums/engine-and-performance/279957-kent25-performance.html#post3555923
