Trend Micro System Cleaner
sakuraguy
5,000 RPM
All In One - Non Install FREE Version
http://img411.imageshack.us/img411/8745/syscleanvc5.gif
Trend Micro System Cleaner is a a free comprehensive stand-alone virus removal utility using the latest virus definition file from Trend Micro used to detect and remove major viruses.
It can detect, clean or erase malware like viruses, worms and trojan horses. It replaces the traditional fix tool by addressing a wide variety of system infections rather than a specific malware infection. This program is not to be used as a permanent anti-virus solution. You can use this tool to clean up an infected system or as a second opinion for your current anti-virus scanner.
Trend Micro System Cleaner also produces a log file in which the scanning results are stored.
Features:
- Hassle free - Easy to install and to use.
- Scan for and delete all malware copies in all local hard drives.
- The fastest protection against new virus outbreaks.
- Terminate all malware instances in memory.
- Remove malware entries from system files.
- Uses powerful virus scanning engine.
- Remove malware registry entries.
- Creates detailed scan reports.
- User friendly interface.
Check the official site often to get the latest scan engine and pattern from time to time.
Go to this link: http://www.trendmicro.com/download/pattern.asp
Download and extract to the Trend Micro System Cleaner folder, if you have downloaded the new virus pattern, remove the old ones from the direcory its usually named LPT$VPN.xxx. Below files ..
- Virus Pattern Files / Cleanup Templates.
- Spyware Pattern Files / Cleanup Templates.
- Spyware Pattern Files for the new SSAPI Anti-Spyware Engine.
- Virus Pattern File (Official Pattern Release) or Virus Pattern File (Controlled Pattern Release).
Go to this link: Trend Micro
Download and extract to the Trend Micro System Cleaner folder below files ..
- Spyware Pattern File (Detection and Cleanup)
NOTE: DO NOT DOWNLOAD AND USE OTHER THAN THE SUPPORT FILES MENTIONED ABOVE, AS THEY WONT WORK.
Thanks and keep it handy in your Portable Drive or USB Drive. Also make sure all the files you have set to READ-ONLY MODE.
Main file download (Not included with patterns n scan engines) here: 2shared - download Trend Micro System Cleaner.rar
Personal comments:
- I have this antivirus in my office computer to manually scan my office computer and server once a week for spyware, malware, virus and also WORM based attacks. This application is very good and reliable if you keep the application scan engine and patterns up to date.
SakuraGuy
Zerotohundred.Com
