Toyota turbo map sensor
allance
enyone know where can find toyota map sensor ? 2jz-gte or 1jz-gte or other toyota turbo engine use
is your wire socket same as mine? if u dont mind, can u pls look at the sensor if this " sensor turbo pressure" written on the sticker same on my pic!! if yes, this means that sensor can be used for turbo car . if this "sensor assy vacuum " written on the sticker means this sensor only for NA car..or u can post the pic at here for me see?
thanks:wavey:
thanks:wavey:
this is the map sensor of 4EFTE:
on my father toyota herrier, just bolt on supercharger,stock map sensor cant reading positive pressure!:nurse:
i have 2jz map sensor..written sensor assy. turbo pressure
part no 89420-14040....thanks..if interest contact me 0136724992
2jz map sensor
part no pix no clear due to cap ayam camera phone
