TOYOTA GR COROLLA Eventuri Air Intake
3,000 RPM
Price
RM 10650
Condition
New
Performance Increase : 15-17hp, 15-18ft-lb
Shown in both Gloss and Matte finishes.
*Images show our optional carbon engine cover.
The GR Corolla Intake follows on from our GR Yaris system which was developed through extensive data logging of temperatures, flow rates and dyno testing. Since this is a turbocharged engine, heat and volume were the main considerations during development. This intake system has been developed to offer the highest possible flow rate whilst maintaining the lowest intake temperatures possible. Each component has been designed to provide the turbo with a smooth and free flowing path. By ensuring a sealed system we have improved on the IAT’s of the OEM airbox whilst at the same time increasing the internal volume to reduce the pressure drop and therefore reduce pumping losses of the turbo. In doing so the turbo is able to operate more efficiently and therefore reaches peak boost sooner to produce a net performance gain.
The filter itself has an outer diameter of 210mm or 8.3″ with a filtration surface area of over 130,000mm^2. The patented Venturi housing has been designed to provide the maximum internal volume possible for the GR Corolla and provides laminar flow to the turbo tube.
RM10650.00
Serious Buyer Only.
postage can be arranged.
RS Auto Accessories | Butterworth
We ship worldwide
if you are interested please Whatsapp/Call us at
Alan @ RS Auto Acc
Alan 012-4038323
