Toyota Corolla AE92 headlight not working
soulfly
Car: Toyota Corolla AE92
Description of problem: Headlight is not working. When I switched on the headlights, the high beam indicator lights up, but there was no low beam. Corner light is working fine. Flicked the switch many times but the high beam indicator wont go off. At first I thought the switch stucked at high beam, but the high beam is working just fine.
Any idea? I've checked the fuses, all seems to look just fine.
Haha! Happen to me last 2 weeks! I send to check... Cheh... The relay wire at the battery disconnected. When that happens, the high beam switch actually on the low beams. Not high beams. Get it checked? :burnout:
my problem, my fog light lits up even when i switch off my ignition.......& all lights turned off.....
found out there was this red wire connected to + terminal, removed it & all settled.
haish.... i couldn't find anything wrong (maybe i cant see the problem). i guess i'll have the car checked by mechanics lah.
UPDATE: Sent to car electrical shop. Some wire under the steering wheel compartment got burnt. Fixed already.
