toyota caldina review
alfagta
Hi guys,
can anyone give me some good 7 bad review or infor for this model,toyota caldina n-spec....wanted so much to own this car but seldom see any toyota fan here talk about this car.....
thanks...
it's a powerful car with 260hp but only come with 4spd auto tranmission...
that why i wonder how powerful can it be?
Saw a fews on the road with bodykit and huge rim. Really look sporty and ganas.. Really chun car..
TOYOTA CALDINA
GENERAL
Body type Wagon
Drive FULL 4WD
Transmission Super intelligent 4 speed automatic (Super ECT)
Displacement, cc 1998
Frame LA-ST246W-DWPZZ
Price of new car, thousands yen (Tokyo area) 2710 (~$22500)
SPECIFICATION (SPECS)
EXTERIOR
Exterior dimensions (LxWxH), mm 4510 x 1740 x 1445
Interior dimensions (LxWxH), mm 1905 x 1455 x 1165
Wheel base, mm 2700
Treads (F/R), mm 1505 / 1505
Ground clearance, mm 145
Curb vehicle weight, kg 1480
Gross vehicle weight, kg
Seating capacity, persons 5
Doors number 5
Min.turning radius, m 5.6
Fuel tank capacity, l 60
ENGINE
Engine model 3S-GTE
Max.power (Net), kw(PS)/rpm 260 ps (191.23 kw) / 6200 rpm
Max.torque(Net), N*m(kg*m)/rpm 33.0 kg*m (323.62 N*m) / 4400 rpm
Power density 5.69
Engine type Serial 4 cylinder DOHC16 valve turbo
Engine information
Fuel system EFI (electronic fuel injection) (Ci (central injection)
Turbocharger Turbo
Fuel type Unleaded premium gasoline
LEV system (Low emission vehicle) Yes
Compression ratio 9
Bore, mm 86
Stroke, mm 86
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 9.4
Fuel consumption at 60 km/h, l/100km
CHASSIS / TRANSMISSION
Power steering Yes
Tires size, front 215/45ZR17
Tires size rear 215/45ZR17
Braking system, front Ventilated disk
Braking system, rear Disk
Suspension system, front Strut type coil spring (stabilizer attaching)
Suspension system, rear Double wishbone type coil spring (stabilizer attaching)
EQUIPMENT
EXTERIOR EQUIPMENT
Sunroof / Moonroof Option
Front fog lamp Present
Rear fog lamp Option
Xenon headlight (Discharge lamp) Present
Projector headlight Not Present
Rear wiper Present
Front spoiler Present
Rear or roof spoiler Present
ABS (Antilock brake system) Present
TCS (Traction control system) Present
LSD (Limited slip differential) Not Present
Privacy glass Present
UV cutting glass Present
Aluminium wheel 17 inch standard
INTERIOR EQUIPMENT
Air conditioner Full automatic
Wood panel Option
Cruise control Not Present
Centralized door lock Present
Power window Present
Steering wheel telescopic Not Present
Steering wheel tilt Present
Leather steering wheel Present
Power front seat Not Present
Power rear seat Not Present
Leather seat Not Present
Falling down type rear seat Divided type
Child seat fixed with seat belt Present
Rear ELR3 point seat belt Present
Front seat pretensioner seat belt Present
Fourth limited front seat belt Present
Side impact bar Present
Airbag (Driver) Present
Airbag (Passenger) Present
Airbag (Side) Option
Audio deck AM/FM radio equipped MD player
CD-player Connected equipment
Car navigation system Option
Colors
Color spectrum Color
Black mica
Super white II
Dark grey mica metallic
Silver mica metallic
Blue mica metallic
Orange metallic
